I've create a solid swept protrusion from a squared cross-section and 2 parallel tangent path lines. However, having created the protrusion, I cannot create a sketch on the surfaces which contain these path lines, only on the cross-section surfaces. If I create the protrusion with only one of these path lines, I can create a sketch on the surface containing that path line, but not its opposite side, where the other path line would be. Is this a design limitation of Solid Edge V20, anyone know? Hope not!
