Solid Edge ST3 MP06 install
Rosy55
Computer
Apr 13, 2011
8
I need to deploy Solid Edge ST3 MP06 update to several computers. Does anyone know if there is a silent install switch I can use for an unattended install?
Rosy55
Below is what I found in the Solid Edge user group. I hope this helps.
Kind regards,
Theodore Turner
Silent Update Installation
Solid Edge Updates can be installed silently, but must be prepared before they will
do so. The following steps outlines the preparation process.
Open SEUPDATE.EXE in Winzip or other compression utility that opens EXEs.
Extract the contents to a folder.
Issue the following from a command line "path\setup -s"
The update will now install silently with no user interaction.
Solid Edge ST3 MP6 on WinXP x64
Insight Server on Win2008 R2 & SQL 2008 R2 x64
SharePoint 3.0 x64
That appears to work great, thank you! The funny thing is that I contacted GTAC support and was told that this can't be done, so I was just starting the process of building my own MSI installer.
Thanks again,
Rosy55
Hello Rosy55
It is only a pleasure. Do you have access to the Solid Edge user forum? There are some guys who really know their stuff.
Theodore
SharePoint 3.0 x64
I don't have access to it at this time, but it sounds like its something I would definately be interested in. Is that forum on this site, or on the siemens site?
rosy55
Awesome, I have a web key and am now logged in. Looks like a ton of information.
Thanks again
Rosy55
