Right after I click on the parts library icon while I am in a fresh assembly, Solid Edge stops responding. It did this when I was running SE on windows 7 beta and still does this on the full release professional version. I am still using windows 7 and have changed the compatibility to Windows Vista and have gone into each application in the file locations to run as administrator and compatibility with vista. I have installed and reinstalled SE v20 three (3) times now and still the same problem. My computer meets the system requirements and SE worked perfectly when I had vista on this computer. I have saved the parts on a flash drive and opened them on another computer with SE v20 on it at work and they open fine. I make an assembly on that computer with the same parts and it works fine. Then I open the assembly and modify parts on my personal computer and it works just fine. But when I click on that blue icon to import more parts..BAM.. it freezes again. There is nothing like this problem that I have found anywhere so that makes me think that it has something to do with my install of windows 7. What should I do now?
