  • Congratulations IRstuff on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Solid pump for plastic grinding.
amitchopra
11
I want to continuously transfer plastic grinding of size approx 5 mm into the base of a water collumn about 10 feet height and dia 5 feet continuously.I would be grateful if someone could guide me as to how this be accomplished.
Other options:
- feed plastic to tank bottom with long auger
- feed plastic to tank top, and mix
Or have a small tank with a mixer, you submerge the plastic bits by mixing and pump from there.
Like MartinLe says, you're better off looking at either agricultural feed machines like this or gravel loading and mixing systems. They make long ones for lifting grain into the top of silos so this sounds like that but in reverse.
Some sort of paddle mixer or agitator would seem to be a good idea
