Solidworks 2010 printing 1:1 scale at 100% of 11x17 paper is not right 3
aliensquale
I have Solidworks 2010, I am printing on 11x17 paper, my sheet and model scales are at 1:1. I choose in page setup to scale 100%. I print the page out, then take my caliper and measure the actual printout to see if the scale is right on to the measurements called out on the drawing... what I'm finding is that the printout is actually slightly larger than 1:1 scale? For instance I have a part that is 5.5" long, and the drawing dimension shows 5.5". When I print it out on 11x17 paper at a 1:1 scale then I use my caliper to measure the actual printout.. my caliper is reading about 5.6". So the scale is not printing correctly... the same holds true for when I save the drawing as a PDF and print the PDF out as well.. same scale issues..
does anybody know why this is?
I know that my laser printer has a setup routine where you printout a box measure the box and input the measurement to calibrate the printer. See if you printer has this. I also use a plotter (inkjet pringing on a paper roll type)where I've printed parts that were 96" long and measureed them with a 96" scale and they were within .010". Darn spot on if you ask me. Make sure you are printing 100" and not fit to page. Also if you can figure out the % difference you can just print 98.2% of size or whatever and get closer. I use accuratly scaled prints all the time for laying out flat patterns on sheet metal or checking a fabricated part.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
I have HP Officejet Pro printer and square dimensioned 100x100 mm is printed accurately.
Most office printers have replaceable feeder rolls. When they wear out they don't feed consistently. Try changing those and see if your scale matches closer.
ymmv, Diego
