Solidworks slows to a crawl with 1000's of holes
powder99
CA
I have a drawing with 1000 or so holes and it takes close to 20 minutes to open. I have read previously that solidworks is not good at handling so many holes. Has anyone else experienced such a major slowdown with Solidworks. I have a pentium 4 2.4 Gig machine with 2 gig RAM
"network drive" ????
That could well be your problem right there!
Make a copy of the offending files on your local machine and compare the times when running locally.
[cheers]
CorBlimeyLimey, Barrie, Ontario.
[bigsmile] Don't Take It Personal, Have Fun While You Learn [bigsmile]
faq559-863
We have gigabit cards making the network very fast. Opening the file is not the issue its when I attempt to change a dimension within the hole pattern.
powder99,
I have an assembly sitting on an optical breadboard with 765 1/4-20UNC tapped holes on each side. I am not having problems with drawings, but my model was rotating very slowly.
I went into Views and Display, and I turned off "HLR Edges in shaded mode". Everythihg is fine now.
If you take the SolidWorks course on handling large assemblies, they recommend this.
JHG
Thanks for the input, I'll try it out
Unfortunately turning off HLR makes no difference. I have suppressed the pattern and when I attempt to unsuppress it takes a good 20 minutes - extremely unproductive!
poeder99
Send the file to the address in my profile & then we can compare the times to see if it's the computer or the file.
[cheers]
[bigsmile] Sign on a Barrie restaurant reads, "We serve Molsons, but we only smoke Ribs" [bigsmile]
faq559-863
