solidworks to pro-e
mechbull
Computer
Nov 28, 2005
36
what is your best method for exporting from solidworks to pro-e
I have been doing IGES files and have been having to fix a lot of surfaces when I do
is there a better way?
Mechbull,
Here is a link to an interesting article I copied off the net regarding your problem.
I've had great success using STeP and IGES. I would take a look at your geometry to see if that's a problem.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Depending on your version of pro/E, you could try a Parasolids export. WF2 can import them.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
Sr IS Technologist
L-3 Communications
so far that parasolids has worked great thanks guys
