keen_mentee
- Aug 11, 2020
- 22
I am running into a problem while using RISA 3D 17.0. I would really appreciate your suggestions.
I have a cupola that is shipped in site in multiple parts (three) and are attached in the site with bolts. I have modeled all the parts in the same workspace. I want to solve only one part at a time. How can I do that in RISA 3D v17.0. I have attached a picture that could be helpful to understand my issue.
I tried unselecting two part, using "Ctrl+L:lock the unselected part of the model. I do not think is solving my problem. I also tried Modify Propertied>>Member Activation and selected "member is not active". This also did not help with my issue. I would appreciate if anyone could clarify these two functions in RISA as well.
I appreciate your time.
Thank you,
Thank you.
Thank you,
Thank you.
