zhanshenjing
Automotive
- Nov 10, 2012
- 19
I am trying to connect a solid cylinder to a shell plate, anyone have some idea how to connect them in Abaqus? Any idea is appreciated. bending moment will be transmitted..
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
ABAQUS_DOCUMENTATION said:Continuum shell elements can be connected directly to first-order continuum solids without any kinematic transition. An appropriate kinematic transition needs to be provided when conventional shell elements are connected to continuum shell elements to correctly transfer the moment/rotation at the reference surface of a conventional shell. Such a transition can be defined with a shell-to-solid coupling constraint or any other kinematic constraint, such as a surface-based coupling constraint, a multi-point constraint, or a linear constraint equation.
