Sorting data in same way as explorer
chunkymonkey
Is it possible to sort Excel data in the same way as Windows Explorer? I realise that Excel has it's own sort rules, but can these be modified in any way (other than just by checking different day or date options)?
i do not quite understand the question...
any continuous range of columns can be sorted by criteria choosen while executing the sort command.
are you thinking about filtering data - the auto-filter feature?
please advise.
-pmover
I'll try and explain:
I've got a list of filenames in one column in an Excel sheet (about 200 or so), and I want to sort this column (data/sort command) using the same character order as Windows explorer.
One problem though - I don't know what order that explorer uses to sort the data, I just know that it's different to that used in Excel.
chunky,
Are you trying to sort these filenames by date? If yes, are the dates in a column separate from the filenames? If yes, are they formated as dates or as text?
I think Explore uses ASCII chr code sort.
Create another column, cause it to contain the ASCII codes for the file names, then sort on that column.
