Souders Brown k factor vs particle size?
maddocks
Petroleum
Aug 21, 2001
343
Does anyone have info relating the Souders Brown k factor to the particle size? For example, if we use the commonly accepted k of 0.35 - what size of particle does this relate to?
We often use higher K's in some services - does this mean we can accept larger particles or more particles being carried over? Is there a particle distribution that has a cutoff for a certain k factor?
I am not sure my knowledge good enough to comment your question.
Since there is no one would like to comment, I think the k (stoke 's law terminal velocity constant)'s relation with diameter (d)
is k = 13310 * d^2 (d is particle size express in inches).
Thank you.
koba78,
Could you please mention your source?
"We don't believe things because they are true, things are true because we believe them."
