Sources for large CNC foam cutting machine
DesignOutsourcing
Automotive
Aug 11, 2004
54
Hi all,
I'd appreciate any leads, suggestions and advice on buying a large 3 or 5-axis CNC machine to cut foam plugs for making composite moulds. What are the drawbacks with only having 3 or 4-axis vs. 5-axis.
New, used or DIY would all be useful as we are on a relatively tight budget. Our biggest mould is about 10m long but we can cut the plug in sections and use a smaller machine.
thanks, Derek
Derek White
Thanks for the lead David,
I had a look and these are hot wire cutters and cannot cut a complex curve.
I have found a few suppliers and the bigger machines start at about half a million new and are about $150,000+ used.
We will probably retrofit a 5-axis welding robot to be a 5-axis milling machine and put it on rails (on the floor, wall or ceiling) with a ball screw to cut the longer blocks. Used welding robots are very cheap and you can use a PC instead of the old controllers.
cheers, derek
Derek White
