I am using a SpacePilot Spaceball which is used to rotate/zoom/pan. My question is: is there a way to pin the rotation points in Solidworks 2010? For example, if you have a long part and you rotate that piece it may fly off the screen or out into space. If one could pin the rotation point to say an area that is being worked on like the end corner or something of that nature so it rotates about that point, it would make life alot easier. Hate to revert back to using the mouse seeing that it helps reduce mouse clicks and moves some of the work to the other hand. Any tips here?
Thanks,
Will
Thanks,
Will
