Spark Arrestor / Flame Arrestor
aerowave89
4
Hi Guys,
Can we use flame arrestor and spark arrestor interchangeably? What is the difference in terms of application?
I plan to build a power pack for an Oil Spill Equipment on board Floating Storage and Offloading (FSO) vessel.
1. Which is the more suitable component to be installed on a 50kW power pack exhaust?
2. What are the parameters that need to be considered in the selection process of spark/flame arrestors?
Please advise.
Thank you,
Tom
I am by no means an expert, but in my limited understanding, a flame arrestor is engineered to quench a flame by absorbing heat, whereas a spark arrestor is intended to prevent solid particles, glowing or otherwise, from exiting a given volume. It seems quite conceivable that the a single device could perform both functions.
"Schiefgehen will, was schiefgehen kann" - das Murphygesetz
Would suspect these would be covered in some NFPA standard - a safety engineer would know which one.
And spark arresters go on exhaust; this power plant undoubtedly needs both.
