BOCH
- Aug 28, 2013
- 32
Good morning guys,
I was checking a column versus buckling using SPColumn software and following ACI318 chapter 10 recomendations for moment magnification procedure .. After the analysis on SPColumn, i have received a message stating the following "Magnified (second-order) moment exceeds 1.4 times first-order moment. Revise column!" .. This is stated in chapter 10.10.2.1 ..
What is the solution of such situation ?
To check this column, i have extracted the forces applied to this column after doing a PDelta analysis in Etabs;
Could this condition be neglected if a non-linear PDelta analysis is done ?
Thank you ..
Thank you ..
