GregLocock
Automotive
- Apr 10, 2001
- 23,736
The Mars idiosyncrasy. Due to the unique properties of
the carbon dioxide molecules at low pressure, Mars is
the only terrestrial-planet atmosphere in the Solar
System experiencing a change in speed of sound right in
the middle of the audible bandwidth (20 Hz – 20 kHz)
[10]. For an acoustic wave with a frequency higher
than ~240 Hz (relaxation frequency), CO2 vibrational
modes activated through collisions do not have time to
relax their energy [11]. In that case, it is as if the
medium has only 5 degrees of freedom compared to 7 at
lower frequencies (3 translational modes, 2 rotational
modes and 1 doubly-degenerate vibrational mode).
Therefore the adiabatic ratio at high frequency is
reduced to γ∞ = 7/5 compared to γ0 = 9/7 at low frequencies.
It turns out that, on Mars, frequencies above 240
Hz travel more than 10 m/s faster than low frequencies.
It may induce a unique listening experience on Mars
with an early arrival of high-pitched sounds compared
to bass.
Cheers
Greg Locock
to bass.
Cheers
Greg Locock
