Spell check in Nx 2
sundeep198
53
Hi all,
Is there a way to check the spelling in Nx. drafting. I have many notes which changes frequently and has to be entered manually.
Sundeep P.
Nx 7.5.4.4
No.
When I have a situation like you I cut and paste the notes into WORD and do the spell check there.
Hi Sundeep...
It is possible to do a spellcheck in NX. Checkmate can do this, but needs a license of course.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
There's a sample NXOpen application that spellchecks notes (it ships with NX). You'll still need MS Word installed because it uses Word's spellcheck routines.
www.nxjournaling.com
Cowski,
Care to share where it may be and what it is called?
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6, NX7.5 & NX8.5
Vericut7.2.3
The files are in the folder: <$UGII_BASE_DIR>\UGOPEN\SampleNXOpenApplications\.NET\SpellChecker.
I'll admit, I've not tried it myself as my spelling is xsellint [rednose]
Looking over the readme file, it appears that you may have to compile it yourself to get it running; but there are instructions.
What I use is a 3rd party application called 'TinySpell+' which runs in the background (when installed it starts when Windows is launched) and works with ANY application where there is a text entry field, including NX.
You can learn more about this appt at:
DISCLAIMER: I have NO business or financial interest in this product nor the organization that produced it.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Siemens NX absolutely has a spell checker built in....It seems not to many people know about it. I'll explain how to set it up so you can use it and not have to do all this crazy stuff you all speak of.
while in your drafting sheet click--> Analysis --> check mate--> set up tests.
"Tests" tab--> expand "Spell Check" towards the bottom. Move both tests to the chosen Tests by clicking the teal arrow at the right.
Click execute check mate. It will show a red x where ever misspellings are.
Enjoy your new knowledge!
Hello Cubalibre00
can you tell me how to execute those file which you have given in the attachment for both NX 8 and TC9.1
