Spherical grinding machines
DennisP
40
I am looking for information on companies that manufacture the equipment, either grinding or turning, to produce spherical radii such as that found on rod ends, etc. I have an application for a machine that can produce a spherical radius of 20mm on the end of a cylinder with a surface finish of 0.8Ra Max. Can someone point me in the direction of some manufacturers of this type of equipment? Thanks.
