hello ..
how can get code to recalculate the culomn calculation for sherical tank becouse i found 2.1 mm thickness reduction arround whole area with height of 800mm , so can not going to any repaing or replacing , i thought of doing recalculation to finding if that 2.1mm corroded column can endourance the tank weight with full service fluid or not
thanks for instruction
