I am investigating a problem with a possible internal leak across a spiral wound gasket. After digging deeper, I found that the spiral wound gasket is oriented such that the pressure in on the outside. I realized that I could not recall ever seeing a spiral wound gasket with OD pressure. I attempted to research this on-line, but did not find any relevant information. I am hoping someone here has some experience in this area.
Just to clarify, I am referring to a standard spiral would gasket of the same configuration as a typical flange gasket for a raised face pipe flange or a head gasket in an API pump. In cross-section, the gasket is composed of wraps of 316 SS with a chevron cross-section. The filler between the wraps is flexible graphite composite. Normally, the pressure would be on the inside of this type of gasket such that the pressure would tend to spread out the chevron, forcing the edges harder against the sealing surfaces on either side. It seems to me that applying external pressure would tend to collapse the chevron shape inward and cause the sides to pull away from the sealing surfaces. But, this is just speculation on my part.
In my particular application, the gasket is subjected to approximately 2000 psid of 350 F gasoil.
Johnny Pellin
Johnny Pellin
