Spot test for H2S
Materials
Jul 23, 2007
5
Please provide spot test procedure/solution for detection of trace amounts of hydrogen sulphide on a steel surface and any reference literature in this regard.
If you want just a qualitative test you can use lead acetate tests strips available at any laboratory supply house.
More meaningful quantitative results can be made using Draeger Tubes.
If you want to have a continuous monitoring system check with your local utility and see which meter they are using.
