Spot testing
Rjeffery
332
Is there a reliable acid spot test to determine if an alloy is predominantly Ti?
The best way to test something is to squeeze it, slowly, until it breaks!
I don't know of any straight acid test that will give you that information. A quick test is to spark it using a grinding wheel and if you get a shower of brilliant white parks you have a lot of Titanium. The only other material that makes this type display is Zirconium.
The two companies below make spot test kits for metals. I don't know if either has a teat for Ti.
Here is one that can sort Titanium alloys.
Can density measurement offer a clue instead?
Chocolates,men,coffee: are somethings liked better rich!!
(noticed in a coffee shop)
Great suggestion by Arun. How large are the parts? Density determination using the Archimedes principle is a simple test method.
Cory
