jangolobow
Chemical
Hallo
I have question. From raw material supplier we obtain material in desired form (cast). We assemble this part and clean it (with first hot water and after with dry ice and again in hot water). Material surface is completely clean. After applying pressure on this part some spots appear on the material surface. We did analyses of those spots and they are from carbohydrates. Does somebody have idea why those spots would appear and from where do the arise? Prior we apply pressure there is no spot after we apply pressure spot appear. Is it possible that there are some impurities “hidden” in material? And after applying pressure they diffuse out from valve body? Applied pressure is up to 600 bar, surrounding temperature (up to 30degC)? We apply pressure by water 8it is clean – spots can not appear from test fluid)!
