greznik91
- Feb 14, 2017
- 186
I have to design spread footings for a barn.
Its a steel barn with pinned supports at columns bases. So that means that the only action on top of a spread footing is vertical and horizontal force/reaction from steel column. Since my footings are 1,20 m deep I get a moment as a result of horizontal reaction at the top of a footing: M = RH x h
Since horizontal forces are pretty big I get a large moment acting on a footing and hence large footing dimensions.
I was thinking about adding another foundation beams as shown in attached picture bellow. Those beams would be connected to RC wall (at the end of a beam).
Because of that moment on footing is no longer a problem and I get much smaller dimensions.
What im asking is:
- do you see any possibly problems caused on a RC wall because of extra foundation beams that are connected to it
- can I consider friction between RC slab and ground/soil and passive soil pressures on footing to take care of horizontal forces acting on a footing?
What im asking is:
