Spring motion at 4.2K
srn
Aerospace
Apr 6, 2001
3
0
0
GB
HI all,
Has anyone ever worked with bronze(or any other type of) springs at low temperatures (4.2K)?
I'm interested in finding out how they behave, as I would like to use one in a gadget I am building.
Thanks,
srn
I'm using a modified optical mirror mount with springs. It works fine at 30K. Not much should change going down to 4.2K. Unless the spring constant is very critical I'd suggest just trying the assembly. Conventional wisdom is that springs stay springs even at low temperature.
FYI, I've also folded aluminum foil very easily at 30K and routed thin wires. They both behave much like they do at room temperature.
HI nevsf!
Thanks for the message.A lot of the the people I have talked with speculated that not much would change in the spring behaviour, but it is good to hear from someone who has actually used them!I trust I would find the same!
Thank you!
srn
