ddddarkbull
Aerospace
I am looking for COTS hardware that can be used to mount 2 extension spring side by side through a steel plate between the 2 springs. The springs are parallel to each other. I hardware should be fixed at the steel plate. I have hard time to find any from internet search. The extension spring has loops at the ends and the mount should allow the spring to spin freely. Would appreciate if someone can provide the source for this hardware. Thanks
