Cockroach
- Jan 17, 2003
- 1,104
I have a Clapper which is held by a 5/32 inch axial to a Seat, a check valve arrangement. The Clapper weights 4 1/2 lbf, the centre of mass is 3 1/16 inches from the centre line of the axial. I need the Clapper to be spring return, 95 degree rotation counter clockwise.
Using a torsion spring, I would need a moment of 14 inch pounds at 5 degrees of rotation. My intended FOS is 1.25, so I would like about 17.0 in lbf at 5 degrees. This means the torsion spring would need to be 1/8 wire, have an OD around 1.0 inch and have a minimum axial space of 1.438 inches. This will not work for me!
I need something that will provide me with about 20 in lbf return at 5 degrees and have an additional travel of 90 degrees. I only have 1.0 inches of axial space, inner core is 5/32 inch slip fit, maximum OD is under 1/2 inch. Clearly the torsion spring idea is dead.
What else can I do? Torsion Bar? Watch Spring? I'm right out of ideas at the moment!
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
Principal
