The SCI(Steel Construction Institute) from UK has a document called "Elastic Design of Single Span Steel Portal Frame Buildings to Eurocode 3".
This document has the following recommendations for modelling of columns bases:
- For ULS, consider the base pinned even if you use a four bolt pattern with the bolts outside the flanges;
- For Stability assessment, consider a Spring Stiffness equal to 0.4EIcolumn/Lcolumn;
- For SLS , consider a Spring Stiffness equal to 0.8EIcolumn/Lcolumn;
I think that i understand the logic behind this approach, which i will describe and if i'm wrong, please someone corrects me:
- For ULS, the bending moment at the base increases significantly the cost of base plates and foundation while it doesn't reduce significantly the bending moments on the rafter;
- Although the foundation and base plate aren't designed for the bending moment, they will resist some and this will be enough to reduce the deflections considerably. ( When i analyze the portal frame with the spring, the bending moments at the base are very small compared to the ones obtained for rigid base)
But although i undersant the reason for the approach, i cannot understand how the base stiffness will be independent on the soil at which the foundation is supported. How can i use the same spring stiffness for a pile cap over sand and for a footing over a soft clay?
Thanks for your help.
