jbeech
New member
- Jan 18, 2010
- 9
I usually see spur gear ratios stated as best for a range between 1:1 and 6:1 (with efficiencies of 98-99%). What happens as you go to higher numerical ratiosn, e.g. 9:1, do efficiencies go down (a little, a lot, enough to make the increased complexity of a 2-stage reduction a better choice)? Where's the sweet spot assuming 20 degree pressure angles?
