Hi Everyone,
I was proposed a weld type that I am not familiar. The condition is for a welded column splice plate. The splice plate width is equal to the width of the column flange. The weld type is called out as a square groove weld along the seam of the splice plate and the column flange. Is this weld considered a CJP or a PJP? What are the limitations of this weld? If possible please provide sections from AISC.
Thanks,
rzoppa
Thanks,
rzoppa
