Hello all,
I am currently in the process of designing an analytical fuel cell. This assembly consists basically of several square blocks of various materials, stacked on top of one another and held together by a series of bolts which seat on the top plate and thread into the bottom plate. The assembly basically consists of 5 plates, 4 of which are about an inch thick. The 5th "plate" is actually a membrane electrode assembly (MEA), and can be treated as a gasket. It is highly beneficial for the MEA to see even compression across its center. To achieve this, I have ensured that the surrounding plates are very stiff and precision ground. My question is, should I employ a circular bolt pattern, or a square/rectangular pattern? I would assume a larger number of bolts is beneficial.
Any tips would be appreciated.
