Dear Experts,
I am reaching out to you to seek your expert advice regarding our 14” OD & 12.7 mm thk. Process Air Line (SS 321 H metallurgy) operating at 550 oC (1022oF) which we intend to replace due to multiple Stress Relaxation related cracking related leakages in the past. Root cause of Stress Relaxation Cracking was identified to be non-compliance to WPS (high heat input) at the time of original construction ( i.e. year 2010).
We are planning to replace our Process Air Line in our upcoming Plant Turnaround and are proceeding with making below mentioned improvements as per Licensor guidelines.
• Use 16-8-2 welding consumable for welding. Previously ER347 was used at the time of original construction.
• Use piping material of grain size of ASTM 3.5 or finer
• Use piping material with Ti/C> 8 and Ti /(C+N) > 7.3
• Ensure Ferrite number is below 5 at welding joint
• Ensure hardness reading is below 200HV at welding joint
• Minimize welding heat input and use stringer bead welding technique
• Weld joint weld capping flushing with pipe base metal to avoid any stress raisers
Additionally, licensor has also recommended carrying out PWHT at 850 o C (1562oF). While we are making arrangements to comply with all aforementioned precautions, we are struggling with necessity and potential drawbacks of carrying out PWHT of filed joints. New SS 321H piping material complies with aforementioned relevant requirements and has also undergone solution annealing and stabilization heat treatment at the foundry.
We would be grateful if you can share your expert view of weather there is any merit in carrying out PWHT and do the intended benefits outweigh the potential drawbacks as we fear that PWHT may result in thermal cracks in the welding joint during PWHT activity.
