STAAD Pro Report
chris456s
50
I'm using STAAD PRo V8i (Select Series 4)
I have a frame structure made of tubular members with an API code check
The API code check assesses the tubulars to API RP 2A section 3 and assesses joints to API RP 2A Section 4
The results of both the Section 3 and Section 4 checks are presented in the output file on 2 separate tables
However, only the Section 3 checks show up in the Staad report under unity checks.
Is there a way to display the joint checks in the report output?
I do not see it in the output options in the report setup.
