suspguy
Automotive
- Mar 20, 2005
- 22
Hello everybody
i was looking up some formulas for calculating stabilizer bar roll stiffness, given things are:
Bar Diameter
Material properties
Lever arm length
Torsional section length
I found some data about it in thread108-40691
But the problem I was having the most formulas available dont take into effect the distance between mount bushings
To get more accurate results I was trying to take into effect the deflection due to rubber bushings as well
The methodology i am using is
1) Calculate the bending moment and torsional moment at bushing center due to vertical load at bar end.
2) Calculate bushing deflection due to bending and torsional load taking into account conical and torsional bushing rates.
3) Add thoose defections to the total deflection at bar end which can then be used to calculate roll stiffness
I am assuming a D-shaped bushing
If I did that would i be wrong??
I am a little confused if I should use radial deflection as well or my line of thought is totally messed up
In short i want to include bushing deflection also to calculate stabilizer bar roll stiffness
Any IDEAS or CORRECTIONS??
Thanks for your help!!!!!
Bar Diameter
Material properties
Lever arm length
