rajeshkumarn
Will the stainless steel rebars used for bridge deck weaken when it is bent at a location? The second part of the question is what will happen if the bent stainless steel rebar bent again at the same location? I have a situation where the contractor wants to bend the SS rebar 90 degrees in a stage construction of the bridge due to limited space between the existing portion of existing structure and want to bend it back to a straight line in the next stage when the existing structure is demolished, so that he can use this portion of rebar for lapping in a closure pour. Any answers will be appreciated.
