MManufacturing
Industrial
- Apr 13, 2007
- 5
Thanks in advance to those willing to lend a hand with this project....
Our company (a custom machine shop) is trying to develop a salt water product. Since we're in the middle of South Dakota, we don't really deal with saltwater anything. hahahah
Basically, we've silver soldered a stainless steel wire (about .08" thick) to a brass plate. The product is then sent to a plater for a special saltwater finish.
When we sent out the product for testing, we found that directly AFTER the soldered joint area, there was a spot of rust forming all around the wire. But.... AFTER the little rust spot, the wire is fine, with no signs of corrosion.
Now, I've read somewhere that this could be caused by us heating the stainless steel too high, causing some sort of carbon problem. Is this correct?
Would someone be able to offer some solutions?
Again, thanks in advance....
