vinothsvk
- May 19, 2016
- 27
Hi all,
I have one clarification on selection of Flange rating.
Normally for Standard Flange (ASME B16.5), we select the Rating based on design conditions(design pressure and Design temperature) only.
But, My vendor select the flange rating based on total required bolt area calculation as per ASME Sec VIII Div I Mandatory Appendix 2-1.
Here I would like to elaborate what happened.
Now, i am looking plate and Frame Heat exchanger. As per design condition of this Equipment (Design Pressure 14.6 & Design temperature 155 degree Celsius, Flange Material is Carbon steel), the Equipment nozzle falls under 150# rating. But, my vendor changed the nozzle rating into 300# based on total required bolt area calculation as per ASME Sec VIII Div I Mandatory Appendix 2-1.
Please confirm, ASME Sec VIII Div I Mandatory Appendix 2-1 is applicable for standard flanges (ASME B16.5)?
