standard liquid flow rate in HYSYS
Buchi
Chemical
Jan 23, 2002
49
Hi all,
HYSYS reports two types of "liquid flowrates" in its conditions results tab as follows;
1. std ideal liq vol. flow in barrels/day
2. liq volume flow@std cond.in barrels/day
the values assigned to these two conditions are usually close. but my question is, what is the real difference between them? and when should one pick either of them?
Buchi
Hi gangs,
i have found the answer to my question. so you don't need to bother.
Buchi
Great that you found the answer for yourself but if you do have other Hysys questions- post them in the Aspen Forum in the Engineering Software for Chemical Engineering Area.
