I currently work with polyurethane parts that we must bolt together. Because of the reduced max compressive stress limit on the PU, I perform non-standard bolt torque calculations in order to preserve the integrity of the PU. For my current project, I noticed that when the fasteners are torqued, I am seeing washer deformation. This surprised me since we are already not reaching max bolt torque. Some information:
5/8-11 UNC, finished hex head cap screw, 316
5/8 washer, ASME B18.21.1 (for soft material), 0.656 ID x 1.750 OD x 0.10 thk (in), 316
5/8-11 UNC Nut, 316
PU hole ID = 0.657 in
Currently torquing to 65 ft*lbf = about 7.3 kip preload
Max compression on PU = 5.5 ksi
I calculate my maximum compressive force as (area under washers) x (max compression on PU) = 11.4 kip
Anyone have a calc that can help me determine why my washer is deforming, or how to determine proper washer thickness?
Thanks!
5/8-11 UNC Nut, 316
Thanks!
