dave57
- Jan 21, 2003
- 5
We have a 75kw motor and recently replaced the all the contactors, following this when the motor ran up, it would trip the overload as soon as it switched to delta, If the motor had no load it switched over fine, we found by increasing the magnetic overload level the breaker will stay in under loaded conditions. I have since put a current clamp meter on all three legs and found two spike from 90A to 160A as the delta contactor comes in, the current level then settles and the motor runs fine, any suggestions as to what is happening here??
