my qustion is:
if i am designing a motor for a load of 50 KW 380 volt with 1000 rpm direct coupling, and i have to design two motors one is star connection and the other is delta connection,
1-what ts the advantage and disadvantage of each connection
2-what is the phase current
as the output torque should be the same for both at this speed, is the phase current is the same?
