Star Trek today?
It will start at home first. Break a knob off of something, download the file and print out a new one. No need to go get or ship anything... if you have a compatible machine in your home.
Next, they'd be doing it with food.
[Homer Simpson]Mmm, printed lasagna...[/Homer Simpson]
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
Even assuming you have that printer at home, it's usually the ink that's the problem, not the printer. So, unless you've got some means of piping the powder and the binder into your house, there'll still be some deliveries to your house.
Note also that the segment cheated, as indicated by one of the comments; they couldn't possibly separate the screw drive and the moving part of the jaw from the point cloud. That bit on the computer was just for show; there are missing details in the finished part that should have been in the point cloud, so it's obvious that they must have created the 3-D CAD file from scratch, and still messed up the details.
TTFN
FAQ731-376
Chinese prisoner wins Nobel Peace Prize
"Break a knob off of something, download the file and print out a new one."
Meh. That knob will break even faster, and it will have cost you 3x what you would have paid for the right part in the first place. I like 3d printers, you can do interesting things with them, but the sci-fi types would have you believe you could build rocket engines with them. Ain't gonna happen, at least not until they can do it at nano scales.
In fairness, the technology has come a long way in the last 10 years or so.
We now get a few small very low volume plastic covers made in ABS by rapid prototyping. With a little post processing to get rid of the lines on the outside they're good enough for our lab instruments.
Posting guidelines faq731-376 (probably not aimed specifically at you)
What is Engineering anyway: faq1088-1484
Imagine how much HP will want to charge for a 'Pasta and Tomato Sause' 3D Italian Food printer cartridge... It would be cheaper to eat Moon rocks.
File this technology beside Flying Cars.
Here is slight variation the process where the plastic scaffold is built with the 3-D printer and infused with stem cells, and presto you have a new organ or in this case a Trachea. this process is progressing quite rapidly.
I have a friend who's son will soon graduate with a MD and a Doctorate in one of the Bioscience Fields and his goal is to work in this field. He is the type of individual needed as his grade point average is 99+ for his entire schooling.
E1BL1
The NTSB just certified a flying car.
I thought flying cars where called light aircraft.
Pat
See FAQ731-376 for tips on use of eng-tips by professional engineers &
for site rules
...light aircraft...
The distinction is that you're supposed to be able land your flying car in your suburban driveway and use it each day to commute to work downtown.
You grabbed the physical with both hands and totally ignored the esoteric...Everyone zoomed off on the replicator and ignored the 'first contact'. I can't help it if y'all if ya can't see far enough into the future. ;-(
Rod
