rockman7892
- Apr 7, 2008
- 1,172
I came across an application recently where a large 3500HP synchronous motor has its brushless excitation field applied as soon as the motor is started. This motor also does not appear to have any sort of controller to control power factor etc... but instead appears to have a manual rheostat that is set prior to starting in order to control the AC input to the rectifier on the static exciter.
I always thought that a synchronous motor was started as an induction motor by use of the armistoir winding and that the rotor field was not applied until the motor is started, reaches full speed, and is in sync with the source.
Am I looking at this application correctly where the field can be applied as soon as the motor is started? Can someone explain why the field would be applied when the motor is started as opposed to after it is up and running? What does applying the field during starting do to the motor itself, power factor, etc...?
There does appear to be a power factor relay which appears to trip the motor circuit if the power factor drops below a certain pre-set value but I'm not sure if this applies for both starting and running, or just while motor is running. There also is a timer relay that will stop the motor circuit if full load field current is not detected in a set amount of time.
