raisinbran
In the mining industry, motors that can satisfactorily move the load have difficulty starting the load because of voltage drops in the system. These particular motors are mechanically connected to the load using fluid couplers to take advantage of the motor breakdown torque. The motors are started across the line. The reduced voltage (80%) lowers the torque enough that sometimes the load (chain conveyor) will not start and must be partially emptied by hand.
I was thinking about capacitor assisted starting to boost the motor voltage until the load is accelerated. The capacitors would be switched on with the motor and switched off sometime after the load is up to speed. With a fluid coupling, the motors come up to spedd very quickly, and the load is accelerated over a 10 second (approx.) time frame. I was not planning on doing anything too sophisticated, possibly just using a timer to turn the capacitors off. I also would assure that the capacitors were off before the motor was switched off.
From what I read in previous threads, there are concerns about over-voltages and over-excitation. Is this just a concern when the motor is switched off, or could I get into problems when the motor is running?
Thanks in advance,
Raisinbran
Thanks in advance,
Raisinbran
