I am asking this on here because I cannot find a conclusive answer anywhere.
I have acetone flowing for ~100 feet from a glass-lined vessel to a steel grounded vessel. The pipe is 2" diameter and lined with polypropylene, thus making it non-conductive.
My understanding is that acetone, despite being a conductive liquid, will generate charge via "Streaming Current", and won't be able to dissipate it until it reaches the steel grounded vessel. How can I find out whether or not I need to implement bonding or grounding measures?
Initially I calculated the Streaming Current, I[sub]s[/sub], then squared it and multiplied by the resistance of acetone, R, (Length of pipe x Specific Resistance / Cross-sectional area), then divided by 2 to calculate power generated. (Extensions of Ohm's Law, I believe)
Then I multiplied by the time it took the acetone to flow through the whole pipe (i.e. t = d/v) to calculate the Energy generated. (Is this the correct time I should be using? Or is it the total time that there is acetone flowing through the line, i.e. if the pump continuously runs for an hour, does t = 3600s?)
Then I compared Energy generated to the MIE of acetone.
Does my method make sense? Or am I missing something? It makes sense to me, but electrical concepts like current/power/resistance/potential do not represent my area of expertise. Does anyone have any resources that can lead me to a conclusive answer? Even NFPA and a bunch of other resources I've looked at discuss the topic at length but give no conclusive answer to my particular question.
Thanks to anyone that can help me out.
