I am using the dynamic, implicit mode (hence static solver) for the first ever time. My last job gave me many 'Negative eigenvalue' warnings. Could someone please tell me what this means?
Negative eigenvalue warnings suggest that there are some instabilities in the model. They might be related to buckling but more likely reason is presence of rigid body modes.
In general, the closer your simulation is to the "real-world", the better. [What constitutes "real-world" is another matter.] So, inertia is a good thing to take into account. A lot of issues you run into in static analyses can simply be addressed by running a dynamic analysis. However, one has to be aware of the consequences i.e., unlike a static analysis, time and inertia are meaningful.
Are you new to this forum? If so, please read these FAQs:
Everything in numerical analysis depends on the specifics of a given problem. If there are instabilities in the model, you need to figure out the source of those instabilities and try to address them. Inertia is not going to fix issues with model set-up.
