Static equilibrium analysis Error
Diyavolpasa
Hello everyone, im trying to do full-vehicle analysis in ADAMS CAR. I have modelled front,rear suspensions , steering and chasis. When i open full assembly with tires, i can not simulate it. It says Static equilibrium analysis has not been successful.
So i tried the simulate with prepared subsystems . I opened the subsytems which are rear,front susp, rear,front tire, steering and body chasis in ADAMS CAR shared folder. Again i saw the same message ;
---- START: ERROR ----
The maximum number of iterations 1000, has been reached.
For the last attempted iteration:
The equation with the largest error was model.TR_Rear_Tires.til_wheel.force Comp = 3 Error = 135760.556779
The variable receiving the largest increment was model.testrig.sse_diff1 Comp = 0 Delta = 809555952.614248.
I changed the maxit to 1000 and still i took that message. I dont know what to do is there anyone can help me please ?
In my model i changed the hardpoints . But the problem is im trying to simulate with the prepared model by ADAMS CAR shared. It is not working either.
