Aravindan280287
Dear all,
TEST TYPE 1:
I have a metal housing with some electronics inside. This housing is kept inside a heating chamber where hot air is circulated at a desired temperature. The hot air is not directly blown into the housing which will make this as a forced convection problem. Instead, the hot air circulates slowly inside the chamber to make the ambient temperature to be the temperature of the hot air. There are some resistors in the electronics which will generate heat from inside the housing. After 3 hours, temperature will be measured on the outside surface of the Housing at different points and also on the PCB.
Test was done. The test results were close to ANSYS simulation results (~2°C variation).
ANSYS Simulation parameters:
Type: Steady state Thermal
Convective heat transfer coefficient: 10W/m2K (Sink)
All other materials were given Thermal Conductivity values
Bonded contact between all parts with program controlled values
Resistor was given Internal heat generation (Source)
TEST TYPE 2:
The same housing was tested outside in open atmosphere with room temperature conditions. And this time, the potting material inside housing was removed during the test (which means a hollow housing without potting). The test results vary with the simulation results (~10°C variation).
All other materials were given Thermal Conductivity values, potting volume is suppressed and hollow space inside.
WHAT WILL BE REASON FOR RESULTS MISMATCH???
Do I need to assign any properties for the void space inside or convection inside?
I would be happy to have valid suggestions.
Thanks all
TEST TYPE 1:
TEST TYPE 2:
Thanks all
