Stealing signal
RichardMid
ZA
Hi
I have been struggling for a while now to get my webcam to work while not attached to a pc, but to a DSP. I have to do this for a project, but can't figure it out. The webcam needs some or other initialization and probably a timing signal to operate. Somehow, I have to capture the initialization procedure that the computer software uses, and simulate it on the DSP, but I have no idea how I'm gonna do that. How can I "tap" or record the signal that the PC and the webcam says to each other during initialization and operation?
The setup is: webcam connected to a USB to parallel interface IC, and onto the DSP.
I contacted Logitech, but the tech support say they are not allowed to tell me anything.
Any help appreciated!
thanx
I had to do this with a mouse once (I think it was Logitech too). Although I didn't get it to work completely, I did capture the computer/mouse initialization signal. I just wired up the computer's mouse port to a digital logic analyzer, turned on the computer, and read the signal directly. In your case, I imagine you'd need to find/make some USB to parallel adapter that will expose each of the individual wires. Then you can tap each of the exposed wires with a digital logic analyzer. If you don't have a digital logic analyzer, you can maybe use a 2 oscilloscope, and measure the signal (or lack of) in all the wires individually. Then you can chart out the combined signal on graph paper.
I think it would be a better approach to use an emulator
<nbucska@pcperipherals.com>
