Jan 20, 2025 #1 rQuestionEngineering Mechanical Aug 30, 2012 204 What is the meaning for the model codes below ? 32M4 SRV4
Jan 21, 2025 #2 georgeverghese Chemical Mar 19, 2015 4,987 Write to these people : info@elliott-turbo.com The Elliot centrifugal compressor product brochure I have Bulletin P-25B is most likely ancient - it has physical info on frames 29M, 38M and larger Upvote 0 Downvote
Jan 21, 2025 Thread starter #3 rQuestionEngineering Mechanical Aug 30, 2012 204 Done, no reply . Upvote 0 Downvote
Jan 21, 2025 #4 pierreick Chemical Nov 20, 2005 1,415 HI, 19400 CFM Elliott Compressor with Steam Turbine skid | 20971 | New Used and Surplus Equipment | Phoenix Equipment Unused 19400 CFM Elliott Compressor with Steam Turbine skid. Consisting of Elliot Centrifugal compressor: Model 32M4. Design Inlet Pressure: 15 psia. Design Inlet Temp: 35F. Design Discharge Pressure: 77-90 psia. 17862 CFM - 19400 CFM. Design Speed: 6516 to 7178 RPM. POS-E-Coat 523 on rotor and... www.phxequip.com Call them or drop them an email. They may have documents to support! Pierre Upvote 0 Downvote
